An excellent example WITH the original grillecloth, which has never been reproduced. Philco had their act together with the 118 sets. They receive well and have 10W output! I might have some 118 parts laying around if you find something has malfunctioned!
118H - by Jayce - 03-31-2015, 05:26 PM
RE: 118H - by KCMike - 03-31-2015, 07:16 PM
RE: 118H - by Jayce - 03-31-2015, 09:07 PM
RE: 118H - by Fred Taylor - 03-31-2015, 09:18 PM
RE: 118H - by Ron Ramirez - 04-01-2015, 08:21 AM
RE: 118H - by Eliot Ness - 04-01-2015, 08:23 AM
RE: 118H - by AI2V - 04-05-2015, 12:05 PM
RE: 118H - by PhilcoMike - 04-06-2015, 02:43 PM
RE: 118H - by KCMike - 04-09-2015, 09:30 PM
RE: 118H - by TA Forbes - 05-04-2015, 08:07 PM
There are currently 7034 online users. [Complete List]
» 2 Member(s) | 7032 Guest(s)
