42-PT-93 Please Help
OK, guys, here are the results.
1. Oscillator coil: pins 4 and 5 = 3.5 ohms, pins 2 and 3 = 6.8 ohms
2. No hum when touching grid of 50L6 with a screw driver, powered on
3. With the power on, connected negative probe of my DMM to pin 6 of 7C6 and measured the following:
A. Positive to pin 7 of 35Z3 = 162 volts
B. Positive to pin 4 of 50L6 = infinity (? DMM kept flashing negative)
C. Positive to pin 3 of 50L6 = infinity (? DMM flashes negative)
I can't find the instruction manual for the DMM so I assume flashing negative means infinity.
42-PT-93 Please Help - by dseverson - 05-04-2015, 03:56 PM
RE: 42-PT-93 Please Help - by Nick3092 - 05-04-2015, 04:18 PM
RE: 42-PT-93 Please Help - by morzh - 05-04-2015, 04:21 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-04-2015, 05:04 PM
RE: 42-PT-93 Please Help - by dseverson - 05-05-2015, 12:22 AM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-05-2015, 07:10 AM
RE: 42-PT-93 Please Help - by dseverson - 05-05-2015, 05:21 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-05-2015, 07:34 PM
RE: 42-PT-93 Please Help - by dseverson - 05-05-2015, 09:11 PM
RE: 42-PT-93 Please Help - by dseverson - 05-05-2015, 09:12 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-05-2015, 09:30 PM
RE: 42-PT-93 Please Help - by dseverson - 05-05-2015, 09:16 PM
RE: 42-PT-93 Please Help - by dseverson - 05-05-2015, 10:42 PM
RE: 42-PT-93 Please Help - by dseverson - 05-06-2015, 02:53 PM
RE: 42-PT-93 Please Help - by Nick3092 - 05-06-2015, 03:18 PM
RE: 42-PT-93 Please Help - by dseverson - 05-06-2015, 05:18 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-06-2015, 07:01 PM
RE: 42-PT-93 Please Help - by dseverson - 05-07-2015, 11:18 AM
RE: 42-PT-93 Please Help - by dseverson - 05-12-2015, 12:39 AM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-12-2015, 06:15 AM
RE: 42-PT-93 Please Help - by codefox1 - 05-12-2015, 09:07 AM
RE: 42-PT-93 Please Help - by dseverson - 05-12-2015, 12:38 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-12-2015, 06:49 PM
RE: 42-PT-93 Please Help - by dseverson - 05-12-2015, 09:21 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-12-2015, 09:32 PM
RE: 42-PT-93 Please Help - by dseverson - 05-12-2015, 10:06 PM
RE: 42-PT-93 Please Help - by dseverson - 05-13-2015, 01:13 AM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-13-2015, 04:02 PM
RE: 42-PT-93 Please Help - by dseverson - 05-13-2015, 09:05 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-13-2015, 09:24 PM
RE: 42-PT-93 Please Help - by dseverson - 05-13-2015, 10:12 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-14-2015, 06:14 AM
RE: 42-PT-93 Please Help - by codefox1 - 05-14-2015, 09:19 AM
RE: 42-PT-93 Please Help - by dseverson - 05-14-2015, 11:08 AM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-14-2015, 06:28 PM
RE: 42-PT-93 Please Help - by dseverson - 05-14-2015, 07:27 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-14-2015, 09:12 PM
RE: 42-PT-93 Please Help - by dseverson - 05-14-2015, 09:49 PM
RE: 42-PT-93 Please Help - by dseverson - 05-15-2015, 01:26 AM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-15-2015, 06:43 AM
RE: 42-PT-93 Please Help - by dseverson - 05-15-2015, 01:28 PM
RE: 42-PT-93 Please Help - by dseverson - 05-15-2015, 11:57 PM
RE: 42-PT-93 Please Help - by dseverson - 05-16-2015, 01:15 AM
RE: 42-PT-93 Please Help - by Nick3092 - 05-16-2015, 08:52 AM
RE: 42-PT-93 Please Help - by dseverson - 05-16-2015, 05:52 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-16-2015, 06:38 PM
RE: 42-PT-93 Please Help - by dseverson - 05-19-2015, 11:43 AM
RE: 42-PT-93 Please Help - by Nick3092 - 05-19-2015, 01:09 PM
RE: 42-PT-93 Please Help - by dseverson - 05-19-2015, 03:06 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-19-2015, 09:09 PM
RE: 42-PT-93 Please Help - by dseverson - 05-30-2015, 01:38 AM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-30-2015, 01:14 PM
RE: 42-PT-93 Please Help - by dseverson - 06-03-2015, 02:29 PM
RE: 42-PT-93 Please Help - by Eliot Ness - 06-03-2015, 03:50 PM
RE: 42-PT-93 Please Help - by dseverson - 06-03-2015, 04:52 PM
There are currently 6131 online users. [Complete List]
» 3 Member(s) | 6128 Guest(s)
