610B Cabinet
That's what I was think John, thanks!  I'm going to go ahead and strip it.  I really like this set.  The cabinet is indeed very solid and should come out looking nice.  I think the grill cloth may be original, its in decent shape...what do you think??
[Image: https://www.dropbox.com/s/74vvkpicik4l1p....jpg?raw=1]
610B Cabinet - by klondike98 - 05-05-2015, 02:58 PM
RE: 610B Cabinet - by Eliot Ness - 05-05-2015, 04:26 PM
RE: 610B Cabinet - by klondike98 - 05-05-2015, 04:54 PM
RE: 610B Cabinet - by Ron Ramirez - 05-05-2015, 05:41 PM
RE: 610B Cabinet - by klondike98 - 05-05-2015, 06:07 PM
RE: 610B Cabinet - by OldRestorer - 05-06-2015, 09:46 AM
RE: 610B Cabinet - by klondike98 - 05-06-2015, 09:49 AM
RE: 610B Cabinet - by klondike98 - 12-19-2015, 07:03 PM
RE: 610B Cabinet - by mikethedruid - 12-19-2015, 07:19 PM
RE: 610B Cabinet - by radiorich - 01-01-2016, 01:57 AM
RE: 610B Cabinet - by Ron Ramirez - 01-01-2016, 09:56 AM
RE: 610B Cabinet - by klondike98 - 01-01-2016, 10:25 AM
There are currently 10951 online users. [Complete List]
» 2 Member(s) | 10949 Guest(s)
