Rusty Chassis Restoration Hint
Hello you radio buckeroos and buckerettes.
Many of us run across rusty chassis and if we are going to sell or keep the radio it is important to remove the cancerous rust. Sand paper, files, Naval Jelly and other a-sundry items are used, and after cleaning it up the chassis needs a good soapy wash with water or water with baking powder in it to neutralize all acids or alkalines.
A good production to spray or brush over the chassis work is Rustoleum Galvanox Galvanizing Spray. It is very zinch rich and will kill and stop all future rust after the surface is prep'ed. You may also use a primer if you care too, I do not when using the Galvanox. I have used this product for close to 50 years on tower steel, gates, fence poles and all sorts of metal products that are in the open.
W4SBA
Stan Adams
Memphis
Rusty Chassis Restoration Hint - by stanleybadams - 05-05-2015, 08:45 PM
There are currently 5010 online users. [Complete List]
» 1 Member(s) | 5009 Guest(s)
