Philco 38-10 Bakelite Condenser Rebuild
(05-05-2015, 06:14 PM)klondike98 Wrote:  Welcome to the Phorum!!
You want 0.015uF Y2 safety capacitors.  I get mine from Just Radios and I believe Mouser has them as well.  I usually buy the 250 v rating.
Here's some info on safety caps
Here's a tutorial on getting the bakelite block stuffed.
Thank you very much for the information. I just ordered them from Just Radios, along with some other caps I needed.
RE: Philco 38-10 Bakelite Condenser Rebuild - by Jhunt - 05-06-2015, 06:45 AM
There are currently 4521 online users. [Complete List]
» 2 Member(s) | 4519 Guest(s)
