  • 1 Vote(s) - 5 Average
Model 89 coil rewind..did anyone save their notes?
Quote:Why would I have to bake the coil??
If you don't, the oscillator my not work. Sometimes there is enough moisture in the coil form to keep the oscillator from working.
Bake the form first, rewind the coil then, spray a couple of coats of clear lacquer or enamel to seal the moisture out.
M R Radios   C M Tubes
RE: Model 89 coil rewind..did anyone save their notes? - by Steve Davis - 05-07-2015, 02:33 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 6449 online users. [Complete List]
» 1 Member(s) | 6448 Guest(s)
