Philco 39-17 help needed
Terry,
Thanks for the reply.  This is definitely an original set-up.  I've included a link to a photo of the knob on the net.  I can take the screw off, but I don't want to break the knob, trying to pry it off the shaft...
https://www.google.com/search?q=philco+3...B640%3B480
Philco 39-17 help needed - by SteveG - 05-08-2015, 04:53 PM
RE: Philco 39-17 help needed - by Radioroslyn - 05-09-2015, 04:46 PM
RE: Philco 39-17 help needed - by SteveG - 05-09-2015, 05:13 PM
RE: Philco 39-17 help needed - by Ron Ramirez - 05-09-2015, 08:30 PM
RE: Philco 39-17 help needed - by Radioroslyn - 05-10-2015, 07:04 AM
RE: Philco 39-17 help needed - by SteveG - 05-18-2015, 11:02 PM
RE: Philco 39-17 help needed - by Warren - 05-18-2015, 11:46 PM
