Philco 39-17 help needed
The knob should just pull off once the screw is removed.
Philco 39-17 help needed - by SteveG - 05-08-2015, 04:53 PM
RE: Philco 39-17 help needed - by Radioroslyn - 05-09-2015, 04:46 PM
RE: Philco 39-17 help needed - by SteveG - 05-09-2015, 05:13 PM
RE: Philco 39-17 help needed - by Ron Ramirez - 05-09-2015, 08:30 PM
RE: Philco 39-17 help needed - by Radioroslyn - 05-10-2015, 07:04 AM
RE: Philco 39-17 help needed - by SteveG - 05-18-2015, 11:02 PM
RE: Philco 39-17 help needed - by Warren - 05-18-2015, 11:46 PM
There are currently 4321 online users. [Complete List]
» 1 Member(s) | 4320 Guest(s)
