Model 60 Tuning Condenser Shaft Slipping
Thanks Texasrocker, I appreciate it. From all of the posts I've seen, I'm surmising that this shaft engages to turn the blades based on spring tension against it's end -- managed by the screw on the opposite end of the condenser. If I'm correct, then the fact that the screw is frozen/won't turn either direction may be the culprit. May be, but it doesn't look like a bushing goes on the shaft the way it's designed and with the 3 bearings it has to fit between. Like you said, I'm sure Ron or Chuck will set me straight! Thanks again.
"Ignorance is bliss...'til you have to fix a radio..."
There are currently 10525 online users. [Complete List]
» 4 Member(s) | 10521 Guest(s)
AvatarAvatarAvatarAvatar
