42-1008P ALigntment
I just had same thing happen on my 42-1012 see thread. Found that the Mica Caps around the Osc tube were way off in value. After replacement radio worked and aligned perfect. Also if you get same stations on 2 different frequencies about 1 Mhz apart (image) replacing the mica caps take care of that too.
Skip...
42-1008P ALigntment - by Edisla - 05-10-2015, 11:58 PM
RE: 42-1008P ALigntment - by Warren - 05-11-2015, 12:07 AM
RE: 42-1008P ALigntment - by vecher - 05-11-2015, 09:54 AM
RE: 42-1008P ALigntment - by Edisla - 05-11-2015, 10:43 AM
RE: 42-1008P ALigntment - by vecher - 05-11-2015, 11:29 AM
RE: 42-1008P ALigntment - by Edisla - 05-11-2015, 01:25 PM
RE: 42-1008P ALigntment - by Edisla - 05-11-2015, 09:56 PM
RE: 42-1008P ALigntment - by vecher - 05-11-2015, 11:31 PM
RE: 42-1008P ALigntment - by Edisla - 05-11-2015, 11:57 PM
RE: 42-1008P ALigntment - by Edisla - 05-12-2015, 12:48 AM
RE: 42-1008P ALigntment - by Nick3092 - 05-12-2015, 10:09 AM
RE: 42-1008P ALigntment - by vecher - 05-18-2015, 11:36 PM
RE: 42-1008P ALigntment - by Edisla - 05-20-2015, 09:48 PM
RE: 42-1008P ALigntment - by Ron Ramirez - 05-20-2015, 09:59 PM
RE: 42-1008P ALigntment - by Edisla - 05-20-2015, 10:23 PM
RE: 42-1008P ALigntment - by vecher - 05-20-2015, 10:32 PM
RE: 42-1008P ALigntment - by Edisla - 05-21-2015, 11:41 AM
RE: 42-1008P ALigntment - by vecher - 05-21-2015, 09:18 PM
There are currently 5998 online users. [Complete List]
» 1 Member(s) | 5997 Guest(s)
