42-1008P ALigntment
I had the Caps on hand. Normally you do not have to replace Mica Caps. But looks like these old radios some if not all of the caps drift. Do you have a capacitor meter? easier to check caps around your Osc tube then trying to replace all of them.. Mine were way out of spec..
Skip...
42-1008P ALigntment - by Edisla - 05-10-2015, 11:58 PM
RE: 42-1008P ALigntment - by Warren - 05-11-2015, 12:07 AM
RE: 42-1008P ALigntment - by vecher - 05-11-2015, 09:54 AM
RE: 42-1008P ALigntment - by Edisla - 05-11-2015, 10:43 AM
RE: 42-1008P ALigntment - by vecher - 05-11-2015, 11:29 AM
RE: 42-1008P ALigntment - by Edisla - 05-11-2015, 01:25 PM
RE: 42-1008P ALigntment - by Edisla - 05-11-2015, 09:56 PM
RE: 42-1008P ALigntment - by vecher - 05-11-2015, 11:31 PM
RE: 42-1008P ALigntment - by Edisla - 05-11-2015, 11:57 PM
RE: 42-1008P ALigntment - by Edisla - 05-12-2015, 12:48 AM
RE: 42-1008P ALigntment - by Nick3092 - 05-12-2015, 10:09 AM
RE: 42-1008P ALigntment - by vecher - 05-18-2015, 11:36 PM
RE: 42-1008P ALigntment - by Edisla - 05-20-2015, 09:48 PM
RE: 42-1008P ALigntment - by Ron Ramirez - 05-20-2015, 09:59 PM
RE: 42-1008P ALigntment - by Edisla - 05-20-2015, 10:23 PM
RE: 42-1008P ALigntment - by vecher - 05-20-2015, 10:32 PM
RE: 42-1008P ALigntment - by Edisla - 05-21-2015, 11:41 AM
RE: 42-1008P ALigntment - by vecher - 05-21-2015, 09:18 PM
There are currently 5949 online users. [Complete List]
» 1 Member(s) | 5948 Guest(s)
