Tube shield finish
It looks like it was a nickel plate. Definitely not paint.
Tube shield finish - by Steve D - 05-11-2015, 10:35 AM
RE: Tube shield finish - by Phlogiston - 05-11-2015, 05:00 PM
RE: Tube shield finish - by Ron Ramirez - 05-11-2015, 05:27 PM
RE: Tube shield finish - by codefox1 - 05-12-2015, 09:10 AM
There are currently 6023 online users. [Complete List]
» 1 Member(s) | 6022 Guest(s)
