42-1008P ALigntment
You need to measure the Caps using the Capacitor tester. The mica Caps read a little different depending on if they use 3 dots or 6 dots. Plus it hard to tell the colors on them since they are over 70 years old.
SKip..
42-1008P ALigntment - by Edisla - 05-10-2015, 11:58 PM
RE: 42-1008P ALigntment - by Warren - 05-11-2015, 12:07 AM
RE: 42-1008P ALigntment - by vecher - 05-11-2015, 09:54 AM
RE: 42-1008P ALigntment - by Edisla - 05-11-2015, 10:43 AM
RE: 42-1008P ALigntment - by vecher - 05-11-2015, 11:29 AM
RE: 42-1008P ALigntment - by Edisla - 05-11-2015, 01:25 PM
RE: 42-1008P ALigntment - by Edisla - 05-11-2015, 09:56 PM
RE: 42-1008P ALigntment - by vecher - 05-11-2015, 11:31 PM
RE: 42-1008P ALigntment - by Edisla - 05-11-2015, 11:57 PM
RE: 42-1008P ALigntment - by Edisla - 05-12-2015, 12:48 AM
RE: 42-1008P ALigntment - by Nick3092 - 05-12-2015, 10:09 AM
RE: 42-1008P ALigntment - by vecher - 05-18-2015, 11:36 PM
RE: 42-1008P ALigntment - by Edisla - 05-20-2015, 09:48 PM
RE: 42-1008P ALigntment - by Ron Ramirez - 05-20-2015, 09:59 PM
RE: 42-1008P ALigntment - by Edisla - 05-20-2015, 10:23 PM
RE: 42-1008P ALigntment - by vecher - 05-20-2015, 10:32 PM
RE: 42-1008P ALigntment - by Edisla - 05-21-2015, 11:41 AM
RE: 42-1008P ALigntment - by vecher - 05-21-2015, 09:18 PM
There are currently 5910 online users. [Complete List]
» 1 Member(s) | 5909 Guest(s)
