Model 60 Tuning Condenser Shaft Slipping
I've done all of the above as Chuck directed with no luck. Thoroughly cleaned and lubricated everything with white lithium grease and reassembled. The set/adjustment screw on the back will not turn at all in either direction -- it's frozen in place. Unfortunately, I cannot follow Chuck's direction on adjustment of that screw because it will not turn. Pic of screw attached.
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
"Ignorance is bliss...'til you have to fix a radio..."
There are currently 9564 online users. [Complete List]
» 1 Member(s) | 9563 Guest(s)
