42-PT-93 Please Help
OK, dumb question. Which tab on the on/off switch do I connect the negative probe to and does the radio need to be plugged in?
Tubes are in the correct sockets and I can't see any solder bridges. The antenna coil has no continuity so I will rewind it. I noticed someone fixed a couple breaks in the wire so I have to assume there are others. I haven't touched any of the trimmer caps. The leads to the osc coil are connected.
I'll get back later with the voltage readings once I'm sure how to do it.
42-PT-93 Please Help - by dseverson - 05-04-2015, 03:56 PM
RE: 42-PT-93 Please Help - by Nick3092 - 05-04-2015, 04:18 PM
RE: 42-PT-93 Please Help - by morzh - 05-04-2015, 04:21 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-04-2015, 05:04 PM
RE: 42-PT-93 Please Help - by dseverson - 05-05-2015, 12:22 AM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-05-2015, 07:10 AM
RE: 42-PT-93 Please Help - by dseverson - 05-05-2015, 05:21 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-05-2015, 07:34 PM
RE: 42-PT-93 Please Help - by dseverson - 05-05-2015, 09:11 PM
RE: 42-PT-93 Please Help - by dseverson - 05-05-2015, 09:12 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-05-2015, 09:30 PM
RE: 42-PT-93 Please Help - by dseverson - 05-05-2015, 09:16 PM
RE: 42-PT-93 Please Help - by dseverson - 05-05-2015, 10:42 PM
RE: 42-PT-93 Please Help - by dseverson - 05-06-2015, 02:53 PM
RE: 42-PT-93 Please Help - by Nick3092 - 05-06-2015, 03:18 PM
RE: 42-PT-93 Please Help - by dseverson - 05-06-2015, 05:18 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-06-2015, 07:01 PM
RE: 42-PT-93 Please Help - by dseverson - 05-07-2015, 11:18 AM
RE: 42-PT-93 Please Help - by dseverson - 05-12-2015, 12:39 AM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-12-2015, 06:15 AM
RE: 42-PT-93 Please Help - by codefox1 - 05-12-2015, 09:07 AM
RE: 42-PT-93 Please Help - by dseverson - 05-12-2015, 12:38 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-12-2015, 06:49 PM
RE: 42-PT-93 Please Help - by dseverson - 05-12-2015, 09:21 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-12-2015, 09:32 PM
RE: 42-PT-93 Please Help - by dseverson - 05-12-2015, 10:06 PM
RE: 42-PT-93 Please Help - by dseverson - 05-13-2015, 01:13 AM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-13-2015, 04:02 PM
RE: 42-PT-93 Please Help - by dseverson - 05-13-2015, 09:05 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-13-2015, 09:24 PM
RE: 42-PT-93 Please Help - by dseverson - 05-13-2015, 10:12 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-14-2015, 06:14 AM
RE: 42-PT-93 Please Help - by codefox1 - 05-14-2015, 09:19 AM
RE: 42-PT-93 Please Help - by dseverson - 05-14-2015, 11:08 AM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-14-2015, 06:28 PM
RE: 42-PT-93 Please Help - by dseverson - 05-14-2015, 07:27 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-14-2015, 09:12 PM
RE: 42-PT-93 Please Help - by dseverson - 05-14-2015, 09:49 PM
RE: 42-PT-93 Please Help - by dseverson - 05-15-2015, 01:26 AM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-15-2015, 06:43 AM
RE: 42-PT-93 Please Help - by dseverson - 05-15-2015, 01:28 PM
RE: 42-PT-93 Please Help - by dseverson - 05-15-2015, 11:57 PM
RE: 42-PT-93 Please Help - by dseverson - 05-16-2015, 01:15 AM
RE: 42-PT-93 Please Help - by Nick3092 - 05-16-2015, 08:52 AM
RE: 42-PT-93 Please Help - by dseverson - 05-16-2015, 05:52 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-16-2015, 06:38 PM
RE: 42-PT-93 Please Help - by dseverson - 05-19-2015, 11:43 AM
RE: 42-PT-93 Please Help - by Nick3092 - 05-19-2015, 01:09 PM
RE: 42-PT-93 Please Help - by dseverson - 05-19-2015, 03:06 PM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-19-2015, 09:09 PM
RE: 42-PT-93 Please Help - by dseverson - 05-30-2015, 01:38 AM
RE: 42-PT-93 Please Help - by Radioroslyn - 05-30-2015, 01:14 PM
RE: 42-PT-93 Please Help - by dseverson - 06-03-2015, 02:29 PM
RE: 42-PT-93 Please Help - by Eliot Ness - 06-03-2015, 03:50 PM
RE: 42-PT-93 Please Help - by dseverson - 06-03-2015, 04:52 PM
There are currently 6097 online users. [Complete List]
» 2 Member(s) | 6095 Guest(s)
