  • 1 Vote(s) - 5 Average
I bought a battery op!??
Hey, Doc! I'm also with the AHRS! I'd probably know you if I saw you. Good luck on your Philco. I'll be there every Saturday morning in the forseeable future.
Slave to an RCA Victor CTC-25
I bought a battery op!?? - by doc612 - 05-12-2015, 10:29 PM
RE: I bought a battery op!?? - by sam - 05-12-2015, 11:02 PM
RE: I bought a battery op!?? - by morzh - 05-12-2015, 11:02 PM
RE: I bought a battery op!?? - by TheUniversalDave1 - 05-12-2015, 11:53 PM
RE: I bought a battery op!?? - by Radioroslyn - 05-13-2015, 06:40 AM
RE: I bought a battery op!?? - by klondike98 - 05-13-2015, 08:41 AM
RE: I bought a battery op!?? - by sam - 05-13-2015, 12:47 PM
RE: I bought a battery op!?? - by morzh - 05-13-2015, 02:10 PM
RE: I bought a battery op!?? - by mikethedruid - 05-13-2015, 03:20 PM
RE: I bought a battery op!?? - by doc612 - 05-13-2015, 09:42 PM
RE: I bought a battery op!?? - by codefox1 - 05-14-2015, 08:34 AM
