Differance between Philco 51 Chassis and Philco 52 Chassis?
Not only.
If you have a 20 chassis in 20 and then some 21, or 111 in both 111 and 112, then Zenith "Walton" 9-tuber 9-S-232 is the same as the console 9-S-262, etc.....no one says different models cannot use the same electronics...sorta like some Caddies are Chevys inside.
