38-690 questions
I won't jump into the pinout basing issues commentary but the 5X4 is an easy tube to find on ebay and if you are going to restore the radio having a hacked 5U4 sub as a rectifier tube would diminish the value. From Doug's remarks it should be just a matter of putting the wire connections back, I have a 38-690 and it is a nice radio, been lucky enough to gather a few of Philcos higher tube count 38 models.
38-690 questions - by Guest - 01-19-2009, 12:22 PM
Re: 38-690 questions - by codefox1 - 01-19-2009, 03:42 PM
Re: 38-690 questions - by Doug Houston - 01-19-2009, 04:41 PM
Re: 38-690 questions - by Steve D - 01-19-2009, 06:25 PM
Re: 38-690 questions - by Arran - 01-19-2009, 11:15 PM
Re: 38-690 questions - by Fred R - 01-20-2009, 10:53 AM
Re: 38-690 questions - by FStephenMasek - 01-27-2009, 01:49 AM
Re: 38-690 questions - by Doug Houston - 01-27-2009, 11:06 PM
Re: 38-690 questions - by Arran - 01-28-2009, 04:02 AM
Re: 38-690 questions - by 49Stude63 - 02-01-2009, 01:01 PM
