Transitone 48 250 126
That's a fun set to work on, will look snazzy when you paint the cainet.
Transitone 48 250 126 - by Paul Philco322 - 05-14-2015, 08:06 PM
RE: Transitone 48 250 126 - by codefox1 - 05-15-2015, 08:58 AM
RE: Transitone 48 250 126 - by Paul Philco322 - 05-15-2015, 10:10 PM
RE: Transitone 48 250 126 - by NostalgiaRadioTime - 05-15-2015, 10:54 PM
RE: Transitone 48 250 126 - by Paul Philco322 - 05-16-2015, 09:18 AM
RE: Transitone 48 250 126 - by Paul Philco322 - 05-16-2015, 05:25 PM
RE: Transitone 48 250 126 - by Paul Philco322 - 05-16-2015, 09:19 PM
RE: Transitone 48 250 126 - by Joe Rossi - 05-16-2015, 10:19 PM
RE: Transitone 48 250 126 - by NostalgiaRadioTime - 05-16-2015, 10:41 PM
