Philco 41-231 "Little Bullet"
Sam
Thanks! Icon_biggrin The wire should be soldered to the old rivets to hold the plastic switch housing in place. Mark Vaccaro used two heavy solid wires; soldering each one to one of the old rivets, bending the wires over so that they touched, and soldering them together.
I used one solid wire, bent it appropriately, and soldered each end to each of the old rivets.
The idea is to hold the switch housing in place without letting it fall off.
Now that I sort of know how to use my iPhone for video, I may make some more videos in the future.
Philco 41-231 "Little Bullet" - by Ron Ramirez - 05-16-2015, 11:08 AM
RE: Philco 41-231 "Little Bullet" - by morzh - 05-16-2015, 11:34 AM
RE: Philco 41-231 "Little Bullet" - by morzh - 05-16-2015, 11:40 AM
RE: Philco 41-231 "Little Bullet" - by sam - 05-16-2015, 01:59 PM
RE: Philco 41-231 "Little Bullet" - by Ron Ramirez - 05-16-2015, 02:09 PM
RE: Philco 41-231 "Little Bullet" - by Jeremy S - 05-16-2015, 02:35 PM
