shadow-meter on 116
Yeah, a 100 watt gun is probably most of your problem.  If you don't want to spring for a soldering station like the Weller WESD51 or WES51 you can use a 25 watt iron or maybe even a 45 watt if you're careful.  I prefer a temperature controlled iron, but an el-cheapo like the following will easily get you by:
https://www.parts-express.com/variable-w...s--370-340
Look at the 2nd review by the guy in Lexington.... he is a friend of mine and he loves that iron.
shadow-meter on 116 - by Danny - 05-16-2015, 08:07 PM
RE: shadow-meter on 116 - by Eliot Ness - 05-16-2015, 08:29 PM
RE: shadow-meter on 116 - by Radioroslyn - 05-16-2015, 09:19 PM
RE: shadow-meter on 116 - by morzh - 05-16-2015, 09:25 PM
RE: shadow-meter on 116 - by Hank G - 05-18-2015, 12:23 AM
RE: shadow-meter on 116 - by Danny - 05-19-2015, 07:17 PM
There are currently 5834 online users. [Complete List]
» 1 Member(s) | 5833 Guest(s)
