Model 50, did I jump too fast?
Well this was great, radio arrived ruined. Another lying seller who said he'd remove the speaker and didn't. You can guess what happened to a relatively nice radio. Back to claims again.
73 de,
Gary/N9VU
Model 50, did I jump too fast? - by n9vu - 12-18-2005, 01:11 AM
[No subject] - by Ron Ramirez - 12-19-2005, 01:17 AM
[No subject] - by n9vu - 12-19-2005, 11:04 PM
[No subject] - by n9vu - 12-19-2005, 11:06 PM
[No subject] - by Ron Ramirez - 12-20-2005, 09:40 PM
[No subject] - by n9vu - 12-25-2005, 03:36 AM
[No subject] - by Ron Ramirez - 12-25-2005, 11:30 AM
[No subject] - by n9vu - 12-28-2005, 12:33 AM
Sorry to hear it.... - by zenith82 - 12-29-2005, 11:37 PM
Re: Sorry to hear it.... - by n9vu - 01-06-2006, 10:28 PM
[No subject] - by Ron Ramirez - 01-06-2006, 10:57 PM
[No subject] - by n9vu - 01-07-2006, 01:38 PM
Philco 91 Tuning Condenser
There are currently 10044 online users. [Complete List]
» 2 Member(s) | 10042 Guest(s)
