It's a 220!
Wow, Jayce, great find ! It is probably going to take a ton of work to get it all sorted out, but once it is, you are going to have a sweet machine for playing 78s as well as radio listening. Do keep us posted on the progress.
It's a 220! - by Jayce - 05-15-2015, 07:22 PM
RE: It's a 220! - by mikethedruid - 05-19-2015, 01:27 AM
RE: It's a 220! - by morzh - 05-19-2015, 09:57 AM
RE: It's a 220! - by fegravel - 05-19-2015, 02:37 PM
RE: It's a 220! - by AI2V - 05-31-2015, 10:48 AM
RE: It's a 220! - by PhilcoJohn - 06-02-2015, 06:58 AM
RE: It's a 220! - by morzh - 06-02-2015, 09:53 AM
RE: It's a 220! - by TA Forbes - 06-03-2015, 09:12 AM
RE: It's a 220! - by morzh - 06-03-2015, 09:25 AM
RE: It's a 220! - by TA Forbes - 06-03-2015, 09:55 AM
RE: It's a 220! - by morzh - 06-03-2015, 10:23 AM
