Resistor Part Number
Hi Will,
I would suspect that 20K is OK as it's mentioned in the service notes. If you are finding hard to get the voltage readings I would start at the power supply to be sure that the output is what it should be. Without that baseline you'll be chasing your tail trying to get to work. After the power supply then the audio stages.
GL Terry
Resistor Part Number - by HOTWIRE - 05-17-2015, 04:36 PM
RE: Resistor Part Number - by Radioroslyn - 05-18-2015, 07:14 AM
RE: Resistor Part Number - by sam - 05-18-2015, 11:07 AM
RE: Resistor Part Number - by HOTWIRE - 05-18-2015, 08:30 PM
RE: Resistor Part Number - by Radioroslyn - 05-19-2015, 06:10 AM
RE: Resistor Part Number - by sam - 05-19-2015, 11:53 AM
RE: Resistor Part Number - by Radioroslyn - 05-19-2015, 09:19 PM
There are currently 5894 online users. [Complete List]
» 1 Member(s) | 5893 Guest(s)
