Another question about a 39-6 Philco
Have had some sets that the rotor shaft has a large piece of copper braid soldered to it and the other end grounded. To be sure that it it had a good gnd connection.
Another question about a 39-6 Philco - by Tom72 - 05-19-2015, 11:37 AM
RE: Another question about a 39-6 Philco - by Radioroslyn - 05-20-2015, 07:48 AM
