Philco Chassis Corrosion?
Yes, I need to get my camera back. It's been on loan. Soon as I do I'll post a pic. The corrosion isn't that bad and in fact I'm pretty lucky. My other radios have, at worst some dust, cobwebs and perchance some spider corpses and cadavers, but then I don't have a really big collection yet, only about 10 or 11, some I've had since the 70's.
Philco Chassis Corrosion? - by Michael Dennis - 02-02-2009, 03:52 PM
Re: Philco Chassis Corrosion? - by Ron Ramirez - 02-02-2009, 09:13 PM
Re: Philco Chassis Corrosion? - by 49Stude63 - 02-02-2009, 11:28 PM
Re: Philco Chassis Corrosion? - by Michael Dennis - 02-03-2009, 01:49 AM
Re: Philco Chassis Corrosion? - by BDM - 02-03-2009, 02:03 AM
Re: Philco Chassis Corrosion? - by Michael Dennis - 02-03-2009, 02:22 PM
Re: Philco Chassis Corrosion? - by Texasrocker - 02-04-2009, 01:00 AM
Re: Philco Chassis Corrosion? - by Michael Dennis - 02-04-2009, 01:11 AM
Re: Philco Chassis Corrosion? - by Texasrocker - 02-04-2009, 01:19 AM
Re: Philco Chassis Corrosion? - by Michael Dennis - 02-04-2009, 01:37 AM
Re: Philco Chassis Corrosion? - by Texasrocker - 02-04-2009, 04:12 AM
Re: Philco Chassis Corrosion? - by Michael Dennis - 02-04-2009, 05:49 AM
Re: Philco Chassis Corrosion? - by Arran - 02-05-2009, 07:03 PM
Re: Philco Chassis Corrosion? - by Michael Dennis - 02-05-2009, 08:08 PM
Re: Philco Chassis Corrosion? - by Texasrocker - 02-06-2009, 02:50 AM
There are currently 8869 online users. [Complete List]
» 1 Member(s) | 8868 Guest(s)
