Another question about a 39-6 Philco
     Hi,
     First off let me say thank you to the folks who
     replied to my question. What I have holding the
     tuner to the chassis are those spring clips.
     Morzh - there is a insulated wire going from the top of the
     tuning condenser to point 3 on the antenna transformer, also
     there is a wire going from the top of the tuning condenser to
     the grid cap of 6A7. From the bottom of the tuning condenser
     there is a green insulated wire going to point 1 of the Oscillator
     Transformer. Is this right?
     Nick3092 - would it be possible for you to post a picture of the
     bottom of your 39-6 radio chassis, so I can compare?
     Again thanks to all for the help. Stay tuned for more questions.
     Tom2
Another question about a 39-6 Philco - by Tom72 - 05-19-2015, 11:37 AM
RE: Another question about a 39-6 Philco - by Tom72 - 05-21-2015, 04:07 PM
