Parmak 1929 Help
You are going to need to get your filament voltage up to 4-4.5 volts. Don't think 3 going to work. Got an old car battery??? Could use that with a 5v 5amp regulator (like a LM7805 in a TO3 package) or a LM317K it's adjustable. Back in the late '20's that's what was use to power the filament was a 6v car/ tractor battery. Got an old Farmall or Massey-Ferguson??? DO NOT CONNECT THE 12v CAR BATTERY DIRECTLY TO THE FILAMENT BUSS OR YOU WILL BE LOOKING FOR A NEW SET OF TUBES!!!! As for the tube mounting the one tube that is spring mounted is the detector tube. It's mounted like that to minimize microphics ( a ringing sound when tube is vibrated). The 71A should be inserted into the socket that is connected to the spkr terminal. It's not a deal breaker as the set will work it where ever you put the 71 but will work better if it is in the proper place.
Parmak 1929 Help - by Eric - 05-20-2015, 04:24 PM
RE: Parmak 1929 Help - by Radioroslyn - 05-20-2015, 06:00 PM
RE: Parmak 1929 Help - by Radioroslyn - 05-20-2015, 06:20 PM
RE: Parmak 1929 Help - by Eric - 05-20-2015, 09:16 PM
RE: Parmak 1929 Help - by Radioroslyn - 05-20-2015, 10:30 PM
RE: Parmak 1929 Help - by Eric - 05-21-2015, 09:31 AM
RE: Parmak 1929 Help - by Eric - 05-21-2015, 12:04 PM
RE: Parmak 1929 Help - by mikethedruid - 05-21-2015, 03:34 PM
RE: Parmak 1929 Help - by Radioroslyn - 05-21-2015, 07:09 PM
RE: Parmak 1929 Help - by mikethedruid - 05-21-2015, 07:26 PM
RE: Parmak 1929 Help - by Eric - 05-21-2015, 08:30 PM
RE: Parmak 1929 Help - by mikethedruid - 05-21-2015, 10:40 PM
RE: Parmak 1929 Help - by Radioroslyn - 05-22-2015, 06:16 AM
RE: Parmak 1929 Help - by Eric - 05-22-2015, 08:06 AM
RE: Parmak 1929 Help - by Eric - 05-22-2015, 08:40 AM
RE: Parmak 1929 Help - by mikethedruid - 05-22-2015, 10:24 AM
RE: Parmak 1929 Help - by Radioroslyn - 05-22-2015, 09:24 PM
RE: Parmak 1929 Help - by Eric - 05-23-2015, 10:26 AM
RE: Parmak 1929 Help - by mikethedruid - 05-23-2015, 12:37 PM
RE: Parmak 1929 Help - by Eric - 05-23-2015, 01:16 PM
RE: Parmak 1929 Help - by mikethedruid - 05-23-2015, 05:56 PM
RE: Parmak 1929 Help - by Eric - 05-24-2015, 10:36 AM
RE: Parmak 1929 Help - by Radioroslyn - 05-24-2015, 11:23 AM
RE: Parmak 1929 Help - by Eric - 05-25-2015, 08:38 AM
RE: Parmak 1929 Help - by Radioroslyn - 05-25-2015, 09:50 AM
RE: Parmak 1929 Help - by Eric - 05-25-2015, 12:10 PM
RE: Parmak 1929 Help - by Radioroslyn - 05-25-2015, 02:02 PM
There are currently 5535 online users. [Complete List]
» 2 Member(s) | 5533 Guest(s)
