41-295 RESTORATION UPDATE
I have completed the electronic restoration of the chassis and aligned the IF's and trimmers before final touch-up in cabinet.
I intend to post resistance and voltage tables for future reference.
MY LAST QUESTION:
Does anyone know if the "wine colored" or "brown" push buttons were used in this set?  There is a dial light that comes on when you switch to push buttons and I assume the wine ones would be better since they would transmit some light.
41-295 RESTORATION UPDATE - by millievolt - 05-23-2015, 09:28 AM
RE: 41-295 RESTORATION UPDATE - by Ron Ramirez - 05-23-2015, 01:06 PM
There are currently 5031 online users. [Complete List]
» 1 Member(s) | 5030 Guest(s)
