Philco Beam of Light
Well, I was able to get a needle for that old cartridge. I plugged the changer into radio and then was able to hear noise when I scratched the needle. That's good. But when I tried to turn the turntable it wanted to go then nothing. No movement. when I turn the switch to manual I assume its supposed to rotate. It doesn't..
Since I am not a mechanical type of person.. Where do I start to look. I have the info on changer supplied by chuck. I don't even know where to start on this..
Any help please??
Skip..
Philco Beam of Light - by vecher - 04-27-2015, 10:50 AM
RE: Philco Beam of Light - by sam - 04-27-2015, 11:04 AM
RE: Philco Beam of Light - by Ron Ramirez - 04-27-2015, 12:37 PM
RE: Philco Beam of Light - by vecher - 04-27-2015, 12:44 PM
RE: Philco Beam of Light - by sam - 04-27-2015, 12:51 PM
RE: Philco Beam of Light - by sam - 04-28-2015, 04:42 AM
RE: Philco Beam of Light - by Ron Ramirez - 04-28-2015, 07:31 AM
RE: Philco Beam of Light - by vecher - 04-28-2015, 09:54 AM
RE: Philco Beam of Light - by Ron Ramirez - 04-28-2015, 11:40 AM
RE: Philco Beam of Light - by sam - 04-28-2015, 12:35 PM
RE: Philco Beam of Light - by marv - 04-30-2015, 04:20 PM
RE: Philco Beam of Light - by klondike98 - 04-30-2015, 06:39 PM
RE: Philco Beam of Light - by vecher - 05-08-2015, 11:24 PM
RE: Philco Beam of Light - by vecher - 05-09-2015, 03:07 PM
RE: Philco Beam of Light - by Edisla - 05-12-2015, 10:05 AM
RE: Philco Beam of Light - by vecher - 05-21-2015, 10:37 PM
RE: Philco Beam of Light - by vecher - 05-24-2015, 10:34 PM
RE: Philco Beam of Light - by Warren - 05-25-2015, 01:00 AM
RE: Philco Beam of Light - by vecher - 05-25-2015, 10:44 AM
RE: Philco Beam of Light - by vecher - 05-25-2015, 06:48 PM
RE: Philco Beam of Light - by sam - 05-25-2015, 07:31 PM
RE: Philco Beam of Light - by Warren - 05-25-2015, 09:02 PM
RE: Philco Beam of Light - by vecher - 05-25-2015, 10:01 PM
RE: Philco Beam of Light - by vecher - 05-25-2015, 11:07 PM
RE: Philco Beam of Light - by Arran - 05-26-2015, 12:00 AM
RE: Philco Beam of Light - by sam - 05-26-2015, 01:24 PM
RE: Philco Beam of Light - by Edisla - 05-26-2015, 03:51 PM
RE: Philco Beam of Light - by Warren - 05-26-2015, 10:14 PM
RE: Philco Beam of Light - by vecher - 05-26-2015, 10:49 PM
RE: Philco Beam of Light - by Edisla - 05-27-2015, 01:12 AM
RE: Philco Beam of Light - by sam - 05-27-2015, 04:06 AM
RE: Philco Beam of Light - by vecher - 05-27-2015, 10:02 AM
RE: Philco Beam of Light - by Warren - 05-27-2015, 01:50 PM
RE: Philco Beam of Light - by davidff - 05-27-2015, 03:06 PM
RE: Philco Beam of Light - by Edisla - 05-27-2015, 04:28 PM
RE: Philco Beam of Light - by vecher - 05-27-2015, 11:43 PM
RE: Philco Beam of Light - by Edisla - 05-28-2015, 02:00 AM
RE: Philco Beam of Light - by sam - 05-28-2015, 03:08 AM
RE: Philco Beam of Light - by vecher - 05-28-2015, 10:54 AM
RE: Philco Beam of Light - by sam - 05-28-2015, 12:11 PM
RE: Philco Beam of Light - by vecher - 05-28-2015, 01:50 PM
RE: Philco Beam of Light - by vecher - 05-29-2015, 05:24 PM
RE: Philco Beam of Light - by Warren - 05-29-2015, 08:02 PM
RE: Philco Beam of Light - by Edisla - 05-29-2015, 06:12 PM
RE: Philco Beam of Light - by vecher - 05-29-2015, 07:18 PM
RE: Philco Beam of Light - by vecher - 05-29-2015, 09:23 PM
RE: Philco Beam of Light - by Arran - 05-30-2015, 04:18 AM
RE: Philco Beam of Light - by sam - 05-30-2015, 12:49 AM
RE: Philco Beam of Light - by vecher - 05-30-2015, 11:29 AM
There are currently 5987 online users. [Complete List]
» 3 Member(s) | 5984 Guest(s)
