I spanked the speaker on my 38-116!
I always said spanking is good. Spare the rod, spoil the speaker.
I spanked the speaker on my 38-116! - by Jayce - 05-24-2015, 09:34 PM
RE: I spanked the speaker on my 38-116! - by morzh - 05-24-2015, 10:53 PM
