Have 37-10 working. Need rubber mounts.
I give new meaning to the word amateur . I have a 37-10 that i have re-capped and made some reccomended changes.
it is working from stations around 550 to 1100 but volume is weak and nothing from other bands on the dial listed as police
And or listed countries. Also the entire tuner section moves. I am not sure why or how to tell how much it should move?
Thanks for helping me on my first post.
Hopefully i will make some friends here on the philco phorum. My friends call me T T. Which stands for nothing in particular.
NEXT STEP....
I have the unit working pretty good. Need to know what the rubber mounts do and where i can get them. One in the back and one on each side of the tuning condenser section. Also need to know WHERE TO GET ANTENNAE and knob for the band selector for this 37-10. Then finally how does the chassis mount into the cabinet. I received it in pieces. There are 3 long bolts (about 4" long) But i dont see any place for them???
Again thanks in advance for any advice or help. I have learned quite a bit already.
