Model 60 Tuning Condenser Shaft Slipping
Guys - thank you for all of the help with this issue. After following your advice and quite a bit of work -- and a flurry of 4-letter words here and there -- I was able to get everything apart, cleaned, lubed and reassembled. The tuner is working smooth as silk now!! Thank you.
"Ignorance is bliss...'til you have to fix a radio..."
There are currently 10171 online users. [Complete List]
» 1 Member(s) | 10170 Guest(s)
