Philco 144 gos on
Congrats Don. Your experience says again how much impact the tired old caps have on a radio.
Philco 144 gos on - by Guest - 02-05-2009, 12:33 AM
Re: Philco 144 gos on - by exray - 02-05-2009, 01:28 AM
Re: Philco 144 gos on - by Ron Ramirez - 02-05-2009, 11:47 PM
There are currently 9162 online users. [Complete List]
» 3 Member(s) | 9159 Guest(s)
