Philco Beam of Light
Yes.with the platter off the motor should turn . If not lube itis turning make sure and check if another part is holding it back. If everything is turning make sure the the drive gear presses against the platter well. if motor doesnt seem to have power clean and lube it, which should be done anyway.
Philco Beam of Light - by vecher - 04-27-2015, 10:50 AM
RE: Philco Beam of Light - by sam - 04-27-2015, 11:04 AM
RE: Philco Beam of Light - by Ron Ramirez - 04-27-2015, 12:37 PM
RE: Philco Beam of Light - by vecher - 04-27-2015, 12:44 PM
RE: Philco Beam of Light - by sam - 04-27-2015, 12:51 PM
RE: Philco Beam of Light - by sam - 04-28-2015, 04:42 AM
RE: Philco Beam of Light - by Ron Ramirez - 04-28-2015, 07:31 AM
RE: Philco Beam of Light - by vecher - 04-28-2015, 09:54 AM
RE: Philco Beam of Light - by Ron Ramirez - 04-28-2015, 11:40 AM
RE: Philco Beam of Light - by sam - 04-28-2015, 12:35 PM
RE: Philco Beam of Light - by marv - 04-30-2015, 04:20 PM
RE: Philco Beam of Light - by klondike98 - 04-30-2015, 06:39 PM
RE: Philco Beam of Light - by vecher - 05-08-2015, 11:24 PM
RE: Philco Beam of Light - by vecher - 05-09-2015, 03:07 PM
RE: Philco Beam of Light - by Edisla - 05-12-2015, 10:05 AM
RE: Philco Beam of Light - by vecher - 05-21-2015, 10:37 PM
RE: Philco Beam of Light - by vecher - 05-24-2015, 10:34 PM
RE: Philco Beam of Light - by Warren - 05-25-2015, 01:00 AM
RE: Philco Beam of Light - by vecher - 05-25-2015, 10:44 AM
RE: Philco Beam of Light - by vecher - 05-25-2015, 06:48 PM
RE: Philco Beam of Light - by sam - 05-25-2015, 07:31 PM
RE: Philco Beam of Light - by Warren - 05-25-2015, 09:02 PM
RE: Philco Beam of Light - by vecher - 05-25-2015, 10:01 PM
RE: Philco Beam of Light - by vecher - 05-25-2015, 11:07 PM
RE: Philco Beam of Light - by Arran - 05-26-2015, 12:00 AM
RE: Philco Beam of Light - by sam - 05-26-2015, 01:24 PM
RE: Philco Beam of Light - by Edisla - 05-26-2015, 03:51 PM
RE: Philco Beam of Light - by Warren - 05-26-2015, 10:14 PM
RE: Philco Beam of Light - by vecher - 05-26-2015, 10:49 PM
RE: Philco Beam of Light - by Edisla - 05-27-2015, 01:12 AM
RE: Philco Beam of Light - by sam - 05-27-2015, 04:06 AM
RE: Philco Beam of Light - by vecher - 05-27-2015, 10:02 AM
RE: Philco Beam of Light - by Warren - 05-27-2015, 01:50 PM
RE: Philco Beam of Light - by davidff - 05-27-2015, 03:06 PM
RE: Philco Beam of Light - by Edisla - 05-27-2015, 04:28 PM
RE: Philco Beam of Light - by vecher - 05-27-2015, 11:43 PM
RE: Philco Beam of Light - by Edisla - 05-28-2015, 02:00 AM
RE: Philco Beam of Light - by sam - 05-28-2015, 03:08 AM
RE: Philco Beam of Light - by vecher - 05-28-2015, 10:54 AM
RE: Philco Beam of Light - by sam - 05-28-2015, 12:11 PM
RE: Philco Beam of Light - by vecher - 05-28-2015, 01:50 PM
RE: Philco Beam of Light - by vecher - 05-29-2015, 05:24 PM
RE: Philco Beam of Light - by Warren - 05-29-2015, 08:02 PM
RE: Philco Beam of Light - by Edisla - 05-29-2015, 06:12 PM
RE: Philco Beam of Light - by vecher - 05-29-2015, 07:18 PM
RE: Philco Beam of Light - by vecher - 05-29-2015, 09:23 PM
RE: Philco Beam of Light - by Arran - 05-30-2015, 04:18 AM
RE: Philco Beam of Light - by sam - 05-30-2015, 12:49 AM
RE: Philco Beam of Light - by vecher - 05-30-2015, 11:29 AM
There are currently 5123 online users. [Complete List]
» 1 Member(s) | 5122 Guest(s)
