How to flatten wrinkled veneer?
Thanks for all of the helpful advice!
RE: the hole - it looks like somebody decided the flat top was the perfect surface to drill something else on. :/
I think you've convinced me about replacing the veneer. I haven't done much veneer work but it would be good to learn especially on a nice flat piece like this.
RE: How to flatten wrinkled veneer? - by TimC - 05-25-2015, 01:57 PM
RE: How to flatten wrinkled veneer? - by sam - 05-25-2015, 02:57 PM
RE: How to flatten wrinkled veneer? - by Nathan Slingerland - 05-25-2015, 09:56 PM
RE: How to flatten wrinkled veneer? - by tab10672 - 05-26-2015, 08:49 PM
RE: How to flatten wrinkled veneer? - by codefox1 - 06-11-2015, 11:08 AM
