Philco Model 80 Oscillator Coil
Mark,
I have limited experience with radio restoration but I do think with Philco coils, the primaries are on top. I'm sure Ron and others who do have a lot of experience will weigh in.
Crist
Philco Model 80 Oscillator Coil - by markmokris - 05-25-2015, 10:15 AM
RE: Philco Model 80 Oscillator Coil - by Crist Rigotti - 05-25-2015, 10:24 PM
There are currently 5989 online users. [Complete List]
» 1 Member(s) | 5988 Guest(s)
