Philco Model 80 Oscillator Coil
I just looked at the parts list for the Model 80 and it lists the secondary at 2.4 ohms not 24 as shown in the schematic. This confuses everything. Now I am not sure which side is the secondary, the inner, thinner winding or the outer thicker winding?
And is it a problem that I am measuring 17 ohms between pins 2 and 4? I don't know which winding that matches.
Ron, Chuck, Terry, anyone...would you know which winding is which?
Mark
Philco Model 80 Oscillator Coil - by markmokris - 05-25-2015, 10:15 AM
RE: Philco Model 80 Oscillator Coil - by markmokris - 05-26-2015, 08:04 AM
There are currently 4704 online users. [Complete List]
» 1 Member(s) | 4703 Guest(s)
