GE radio
The 5u4 draws more current on the heater, 3 amps vs 2 for the 5Y3. Don't do it. Shut it down and get the correct tube.
GE radio - by Guest - 03-07-2009, 05:56 PM
Re: GE radio - by codefox1 - 03-07-2009, 07:28 PM
Re: GE radio - by Carl Travis - 03-07-2009, 07:47 PM
Philco 91 Tuning Condenser
