Just got my 15x
No, that cloth is not the same as the 70-90 cloth. Somewhat similar, but not the same.
The Radio Daze #86 *might* be somewhat similar to the original. I can't tell for sure because the picture is too dark. Maybe that cloth is that dark, and if so, then it would not be a good choice. In that case, 70/90 cloth would be better.
Just got my 15x - by Fred Taylor - 05-26-2015, 07:34 PM
RE: Just got my 15x - by Fred Taylor - 05-26-2015, 07:55 PM
RE: Just got my 15x - by Ron Ramirez - 05-26-2015, 08:09 PM
RE: Just got my 15x - by Chuck Schwark - 05-26-2015, 09:39 PM
