Philco Beam of Light
#35
Questions about the BoL setup
- Is the new motor a Philco part?
- I assume the tech had some paperwork and a kit when he would do the work, is there paperwork on this mod?
- The cabinet light switch, is that supposed to be triggered when the door opens?
- Mine did not and thought maybe that part was taken out. That or its just to be switched manually.
Philco Beam of Light - by vecher - 04-27-2015, 10:50 AM
RE: Philco Beam of Light - by sam - 04-27-2015, 11:04 AM
RE: Philco Beam of Light - by Ron Ramirez - 04-27-2015, 12:37 PM
RE: Philco Beam of Light - by vecher - 04-27-2015, 12:44 PM
RE: Philco Beam of Light - by sam - 04-27-2015, 12:51 PM
RE: Philco Beam of Light - by sam - 04-28-2015, 04:42 AM
RE: Philco Beam of Light - by Ron Ramirez - 04-28-2015, 07:31 AM
RE: Philco Beam of Light - by vecher - 04-28-2015, 09:54 AM
RE: Philco Beam of Light - by Ron Ramirez - 04-28-2015, 11:40 AM
RE: Philco Beam of Light - by sam - 04-28-2015, 12:35 PM
RE: Philco Beam of Light - by marv - 04-30-2015, 04:20 PM
RE: Philco Beam of Light - by klondike98 - 04-30-2015, 06:39 PM
RE: Philco Beam of Light - by vecher - 05-08-2015, 11:24 PM
RE: Philco Beam of Light - by vecher - 05-09-2015, 03:07 PM
RE: Philco Beam of Light - by Edisla - 05-12-2015, 10:05 AM
RE: Philco Beam of Light - by vecher - 05-21-2015, 10:37 PM
RE: Philco Beam of Light - by vecher - 05-24-2015, 10:34 PM
RE: Philco Beam of Light - by Warren - 05-25-2015, 01:00 AM
RE: Philco Beam of Light - by vecher - 05-25-2015, 10:44 AM
RE: Philco Beam of Light - by vecher - 05-25-2015, 06:48 PM
RE: Philco Beam of Light - by sam - 05-25-2015, 07:31 PM
RE: Philco Beam of Light - by Warren - 05-25-2015, 09:02 PM
RE: Philco Beam of Light - by vecher - 05-25-2015, 10:01 PM
RE: Philco Beam of Light - by vecher - 05-25-2015, 11:07 PM
RE: Philco Beam of Light - by Arran - 05-26-2015, 12:00 AM
RE: Philco Beam of Light - by sam - 05-26-2015, 01:24 PM
RE: Philco Beam of Light - by Edisla - 05-26-2015, 03:51 PM
RE: Philco Beam of Light - by Warren - 05-26-2015, 10:14 PM
RE: Philco Beam of Light - by vecher - 05-26-2015, 10:49 PM
RE: Philco Beam of Light - by Edisla - 05-27-2015, 01:12 AM
RE: Philco Beam of Light - by sam - 05-27-2015, 04:06 AM
RE: Philco Beam of Light - by vecher - 05-27-2015, 10:02 AM
RE: Philco Beam of Light - by Warren - 05-27-2015, 01:50 PM
RE: Philco Beam of Light - by davidff - 05-27-2015, 03:06 PM
RE: Philco Beam of Light - by Edisla - 05-27-2015, 04:28 PM
RE: Philco Beam of Light - by vecher - 05-27-2015, 11:43 PM
RE: Philco Beam of Light - by Edisla - 05-28-2015, 02:00 AM
RE: Philco Beam of Light - by sam - 05-28-2015, 03:08 AM
RE: Philco Beam of Light - by vecher - 05-28-2015, 10:54 AM
RE: Philco Beam of Light - by sam - 05-28-2015, 12:11 PM
RE: Philco Beam of Light - by vecher - 05-28-2015, 01:50 PM
RE: Philco Beam of Light - by vecher - 05-29-2015, 05:24 PM
RE: Philco Beam of Light - by Warren - 05-29-2015, 08:02 PM
RE: Philco Beam of Light - by Edisla - 05-29-2015, 06:12 PM
RE: Philco Beam of Light - by vecher - 05-29-2015, 07:18 PM
RE: Philco Beam of Light - by vecher - 05-29-2015, 09:23 PM
RE: Philco Beam of Light - by Arran - 05-30-2015, 04:18 AM
RE: Philco Beam of Light - by sam - 05-30-2015, 12:49 AM
RE: Philco Beam of Light - by vecher - 05-30-2015, 11:29 AM
There are currently 5880 online users. [Complete List]
» 1 Member(s) | 5879 Guest(s)
