Philco Model 20 1930 Lowboy
Yes, in 20 lowboys surviving grillcloth is almost nonexistant.
Chassis is clean, 71a are present (e pensive tubes) and if the speaker is working (and judging by the grillcloth it at least has good cone) this alone is a 100 bucks right there. I would not think much.
Philco Model 20 1930 Lowboy - by Crist Rigotti - 05-27-2015, 10:58 PM
RE: Philco Model 20 1930 Lowboy - by morzh - 05-27-2015, 11:13 PM
RE: Philco Model 20 1930 Lowboy - by sam - 05-28-2015, 02:46 AM
RE: Philco Model 20 1930 Lowboy - by GarySP - 05-28-2015, 08:25 AM
RE: Philco Model 20 1930 Lowboy - by morzh - 05-28-2015, 11:03 AM
RE: Philco Model 20 1930 Lowboy - by PhilcoJohn - 05-29-2015, 06:59 AM
RE: Philco Model 20 1930 Lowboy - by Art Hoch - 05-29-2015, 11:54 AM
RE: Philco Model 20 1930 Lowboy - by mikethedruid - 05-30-2015, 07:01 PM
RE: Philco Model 20 1930 Lowboy - by morzh - 05-31-2015, 11:07 AM
RE: Philco Model 20 1930 Lowboy - by GarySP - 05-31-2015, 04:48 PM
RE: Philco Model 20 1930 Lowboy - by morzh - 05-31-2015, 04:53 PM
RE: Philco Model 20 1930 Lowboy - by GarySP - 05-31-2015, 09:26 PM
RE: Philco Model 20 1930 Lowboy - by GarySP - 05-31-2015, 09:35 PM
RE: Philco Model 20 1930 Lowboy - by morzh - 05-31-2015, 11:12 PM
RE: Philco Model 20 1930 Lowboy - by Fred Taylor - 06-01-2015, 08:01 AM
RE: Philco Model 20 1930 Lowboy - by morzh - 06-01-2015, 10:13 AM
RE: Philco Model 20 1930 Lowboy - by GarySP - 06-07-2015, 06:32 PM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
There are currently 3509 online users. [Complete List]
» 2 Member(s) | 3507 Guest(s)
