41-280 Coil Assembly Clips
I was missing one of those clips that hold the coils down and figured I'd try and make something.
Then one of those springy paper clips came to mind.
Its a bit thicker but maybe it will just work.
[Image: http://i1289.photobucket.com/albums/b519...iecbif.jpg]
Cut it down a bit, spread it out a tad and filed the the tips to take off any sharp points
[Image: http://i1289.photobucket.com/albums/b519...lbb3pv.jpg]
Installed and holding rather well (middle coil in pic). There may be a better smaller paper clip available but this is working.
[Image: http://i1289.photobucket.com/albums/b519...ue1rds.jpg]
Anyway, others may have done same I'm just throwing this out there Icon_smile
41-280 Coil Assembly Clips - by Edisla - 05-28-2015, 11:10 PM
RE: 41-280 Coil Assembly Clips - by sam - 05-29-2015, 03:58 AM
RE: 41-280 Coil Assembly Clips - by klondike98 - 05-29-2015, 08:41 AM
There are currently 4997 online users. [Complete List]
» 2 Member(s) | 4995 Guest(s)
