Philco Beam of Light
#43
I'm thinking all those missing parts is part of the modification.
All the same is missing from mine.
The speed adjust just dangles down under there.
Speed seems fine on the crap records I have. I assume the new motor is just good enough to pass for the one speed.
Philco Beam of Light - by vecher - 04-27-2015, 10:50 AM
RE: Philco Beam of Light - by sam - 04-27-2015, 11:04 AM
RE: Philco Beam of Light - by Ron Ramirez - 04-27-2015, 12:37 PM
RE: Philco Beam of Light - by vecher - 04-27-2015, 12:44 PM
RE: Philco Beam of Light - by sam - 04-27-2015, 12:51 PM
RE: Philco Beam of Light - by sam - 04-28-2015, 04:42 AM
RE: Philco Beam of Light - by Ron Ramirez - 04-28-2015, 07:31 AM
RE: Philco Beam of Light - by vecher - 04-28-2015, 09:54 AM
RE: Philco Beam of Light - by Ron Ramirez - 04-28-2015, 11:40 AM
RE: Philco Beam of Light - by sam - 04-28-2015, 12:35 PM
RE: Philco Beam of Light - by marv - 04-30-2015, 04:20 PM
RE: Philco Beam of Light - by klondike98 - 04-30-2015, 06:39 PM
RE: Philco Beam of Light - by vecher - 05-08-2015, 11:24 PM
RE: Philco Beam of Light - by vecher - 05-09-2015, 03:07 PM
RE: Philco Beam of Light - by Edisla - 05-12-2015, 10:05 AM
RE: Philco Beam of Light - by vecher - 05-21-2015, 10:37 PM
RE: Philco Beam of Light - by vecher - 05-24-2015, 10:34 PM
RE: Philco Beam of Light - by Warren - 05-25-2015, 01:00 AM
RE: Philco Beam of Light - by vecher - 05-25-2015, 10:44 AM
RE: Philco Beam of Light - by vecher - 05-25-2015, 06:48 PM
RE: Philco Beam of Light - by sam - 05-25-2015, 07:31 PM
RE: Philco Beam of Light - by Warren - 05-25-2015, 09:02 PM
RE: Philco Beam of Light - by vecher - 05-25-2015, 10:01 PM
RE: Philco Beam of Light - by vecher - 05-25-2015, 11:07 PM
RE: Philco Beam of Light - by Arran - 05-26-2015, 12:00 AM
RE: Philco Beam of Light - by sam - 05-26-2015, 01:24 PM
RE: Philco Beam of Light - by Edisla - 05-26-2015, 03:51 PM
RE: Philco Beam of Light - by Warren - 05-26-2015, 10:14 PM
RE: Philco Beam of Light - by vecher - 05-26-2015, 10:49 PM
RE: Philco Beam of Light - by Edisla - 05-27-2015, 01:12 AM
RE: Philco Beam of Light - by sam - 05-27-2015, 04:06 AM
RE: Philco Beam of Light - by vecher - 05-27-2015, 10:02 AM
RE: Philco Beam of Light - by Warren - 05-27-2015, 01:50 PM
RE: Philco Beam of Light - by davidff - 05-27-2015, 03:06 PM
RE: Philco Beam of Light - by Edisla - 05-27-2015, 04:28 PM
RE: Philco Beam of Light - by vecher - 05-27-2015, 11:43 PM
RE: Philco Beam of Light - by Edisla - 05-28-2015, 02:00 AM
RE: Philco Beam of Light - by sam - 05-28-2015, 03:08 AM
RE: Philco Beam of Light - by vecher - 05-28-2015, 10:54 AM
RE: Philco Beam of Light - by sam - 05-28-2015, 12:11 PM
RE: Philco Beam of Light - by vecher - 05-28-2015, 01:50 PM
RE: Philco Beam of Light - by vecher - 05-29-2015, 05:24 PM
RE: Philco Beam of Light - by Warren - 05-29-2015, 08:02 PM
RE: Philco Beam of Light - by Edisla - 05-29-2015, 06:12 PM
RE: Philco Beam of Light - by vecher - 05-29-2015, 07:18 PM
RE: Philco Beam of Light - by vecher - 05-29-2015, 09:23 PM
RE: Philco Beam of Light - by Arran - 05-30-2015, 04:18 AM
RE: Philco Beam of Light - by sam - 05-30-2015, 12:49 AM
RE: Philco Beam of Light - by vecher - 05-30-2015, 11:29 AM
There are currently 6120 online users. [Complete List]
» 2 Member(s) | 6118 Guest(s)
