Philco Model 20 1930 Lowboy
SWEET RADIO !!! I don't think that was any standard antenna, but an early add on to eliminate the need for an outdoor antenna. I was told about trying this by an elderly friend when I was a kid, and have used very similar antennas on consoles myself with very good results. It is definitely something I would keep, although I might rebuild it with new cloth covered wire. It will be quite directional however, so you will find stations toward the front and back direction of the receiver will be stronger than those coming from either side.
Philco Model 20 1930 Lowboy - by Crist Rigotti - 05-27-2015, 10:58 PM
RE: Philco Model 20 1930 Lowboy - by morzh - 05-27-2015, 11:13 PM
RE: Philco Model 20 1930 Lowboy - by sam - 05-28-2015, 02:46 AM
RE: Philco Model 20 1930 Lowboy - by GarySP - 05-28-2015, 08:25 AM
RE: Philco Model 20 1930 Lowboy - by morzh - 05-28-2015, 11:03 AM
RE: Philco Model 20 1930 Lowboy - by PhilcoJohn - 05-29-2015, 06:59 AM
RE: Philco Model 20 1930 Lowboy - by Art Hoch - 05-29-2015, 11:54 AM
RE: Philco Model 20 1930 Lowboy - by mikethedruid - 05-30-2015, 07:01 PM
RE: Philco Model 20 1930 Lowboy - by morzh - 05-31-2015, 11:07 AM
RE: Philco Model 20 1930 Lowboy - by GarySP - 05-31-2015, 04:48 PM
RE: Philco Model 20 1930 Lowboy - by morzh - 05-31-2015, 04:53 PM
RE: Philco Model 20 1930 Lowboy - by GarySP - 05-31-2015, 09:26 PM
RE: Philco Model 20 1930 Lowboy - by GarySP - 05-31-2015, 09:35 PM
RE: Philco Model 20 1930 Lowboy - by morzh - 05-31-2015, 11:12 PM
RE: Philco Model 20 1930 Lowboy - by Fred Taylor - 06-01-2015, 08:01 AM
RE: Philco Model 20 1930 Lowboy - by morzh - 06-01-2015, 10:13 AM
RE: Philco Model 20 1930 Lowboy - by GarySP - 06-07-2015, 06:32 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3536 online users. [Complete List]
» 3 Member(s) | 3533 Guest(s)
