40-180 tube changes
(05-30-2015, 07:50 PM)mikethedruid Wrote:  Here is data on the 6J8  http://www.radiomuseum.org/tubes/tube_6j8g.html  .  And here is the 7J7  http://www.radiomuseum.org/tubes/tube_7j7.html  . They are electronically the same tube, but based differently, and the 6J8 uses a cap..  Hope it is of help
Thanks Mike,
That's what I needed. It's a start.
Pat
40-180 tube changes - by Patrick - 05-30-2015, 05:53 PM
RE: 40-180 tube changes - by Radioroslyn - 05-30-2015, 07:48 PM
RE: 40-180 tube changes - by Patrick - 05-30-2015, 08:29 PM
RE: 40-180 tube changes - by Patrick - 05-31-2015, 07:43 AM
RE: 40-180 tube changes - by mikethedruid - 05-30-2015, 07:50 PM
RE: 40-180 tube changes - by Patrick - 05-30-2015, 08:31 PM
RE: 40-180 tube changes - by Radioroslyn - 05-31-2015, 07:32 AM
RE: 40-180 tube changes - by Patrick - 05-31-2015, 07:51 AM
RE: 40-180 tube changes - by Radioroslyn - 05-31-2015, 08:46 AM
RE: 40-180 tube changes - by Raleigh - 05-31-2015, 04:13 PM
RE: 40-180 tube changes - by Patrick - 06-06-2015, 06:05 PM
RE: 40-180 tube changes - by Radioroslyn - 06-07-2015, 08:47 AM
RE: 40-180 tube changes - by Patrick - 06-07-2015, 09:39 AM
RE: 40-180 tube changes - by Radioroslyn - 06-07-2015, 10:11 AM
RE: 40-180 tube changes - by Patrick - 06-07-2015, 10:40 AM
RE: 40-180 tube changes - by Patrick - 06-07-2015, 01:32 PM
RE: 40-180 tube changes - by codefox1 - 06-07-2015, 11:03 AM
RE: 40-180 tube changes - by Patrick - 06-07-2015, 11:48 AM
There are currently 5895 online users. [Complete List]
» 2 Member(s) | 5893 Guest(s)
