UPDATE: Tubes tested. Canadian Philco Radio: ID and repair needed
Well, despite the tube emissions testing, 2 tubes were dead. 1N5G and the 1A7G were toast. They have been replaced and the set plays.
However, it's very Squealy and extremely Quiet. Does this mean the IF etc needs tuned?
The SW also seems dead. Ive read this may be a wartime censorship move? How can I test this?
-Ritchie.
RE: UPDATE: Tubes tested. Canadian Philco Radio: ID and repair needed - by Ritchie - 05-30-2015, 08:48 PM
There are currently 5506 online users. [Complete List]
» 1 Member(s) | 5505 Guest(s)
