40-180 tube changes
Hmmmm... Seems like you got 60v missing. Pull the tube and see if it going up to 150v if so may have a bad tube or something is causing it to haul down a lot of current (incorrect voltages on the grid or cathode).
40-180 tube changes - by Patrick - 05-30-2015, 05:53 PM
RE: 40-180 tube changes - by Radioroslyn - 05-30-2015, 07:48 PM
RE: 40-180 tube changes - by Patrick - 05-30-2015, 08:29 PM
RE: 40-180 tube changes - by Patrick - 05-31-2015, 07:43 AM
RE: 40-180 tube changes - by mikethedruid - 05-30-2015, 07:50 PM
RE: 40-180 tube changes - by Patrick - 05-30-2015, 08:31 PM
RE: 40-180 tube changes - by Radioroslyn - 05-31-2015, 07:32 AM
RE: 40-180 tube changes - by Patrick - 05-31-2015, 07:51 AM
RE: 40-180 tube changes - by Radioroslyn - 05-31-2015, 08:46 AM
RE: 40-180 tube changes - by Raleigh - 05-31-2015, 04:13 PM
RE: 40-180 tube changes - by Patrick - 06-06-2015, 06:05 PM
RE: 40-180 tube changes - by Radioroslyn - 06-07-2015, 08:47 AM
RE: 40-180 tube changes - by Patrick - 06-07-2015, 09:39 AM
RE: 40-180 tube changes - by Radioroslyn - 06-07-2015, 10:11 AM
RE: 40-180 tube changes - by Patrick - 06-07-2015, 10:40 AM
RE: 40-180 tube changes - by Patrick - 06-07-2015, 01:32 PM
RE: 40-180 tube changes - by codefox1 - 06-07-2015, 11:03 AM
RE: 40-180 tube changes - by Patrick - 06-07-2015, 11:48 AM
There are currently 5260 online users. [Complete List]
» 1 Member(s) | 5259 Guest(s)
