Philco 90 serial number
$650 sounds a smidge too high but: if this is original, it looks marvellous and does not seem to neee any restoration of the cabinet, the chassis looks exceptionally clean and if this is unrestored I would ask where it was kept, in museum or something. Thinking of how much effort the resto is, an extra 100 bucks will not set anyone on the way to bancruptcy.
Philco 90 serial number - by sdradioman - 05-31-2015, 07:21 PM
RE: Philco 90 serial number - by Steve Davis - 05-31-2015, 08:14 PM
RE: Philco 90 serial number - by klondike98 - 05-31-2015, 08:20 PM
RE: Philco 90 serial number - by sdradioman - 05-31-2015, 09:37 PM
RE: Philco 90 serial number - by morzh - 05-31-2015, 11:07 PM
RE: Philco 90 serial number - by sdradioman - 06-01-2015, 02:01 PM
