Philco 90 serial number
The gentleman said that he bought it at an auction. He restores antique furniture and says the cabinet is near flawless. The only thing he had to do was wipe down the cabinet and oil it. The chassis has been restored electrically and cosmetically so from what I can see there is nothing that needs to be done but enjoy it! I hope that is the case. Definitely going to go over it with a fine tooth comb and listen to it awhile before I hand the cash over. Thanks for all the help!
Philco 90 serial number - by sdradioman - 05-31-2015, 07:21 PM
RE: Philco 90 serial number - by Steve Davis - 05-31-2015, 08:14 PM
RE: Philco 90 serial number - by klondike98 - 05-31-2015, 08:20 PM
RE: Philco 90 serial number - by sdradioman - 05-31-2015, 09:37 PM
RE: Philco 90 serial number - by morzh - 05-31-2015, 11:07 PM
RE: Philco 90 serial number - by sdradioman - 06-01-2015, 02:01 PM
